07-25-2017 01:28 PM
Following the current guide for upgrading our collector.
http://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Upgrade-Guide.pdf
I have reached step 2.2.1 and when I double click on server connection setup it sits at a loading screen. (attached pic) I have tried firefox/
07-25-2017 01:33 PM
Hi Phillip,
Do you have CLI admin, root access to collector? Could you please try upgrading from there? Please do let me know if you need document on the same.
Supriya
07-25-2017 02:16 PM
I am looking at the current document for CLI upgrade.
http://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/Configure-CSPC-Appliance-via-CLI.pdf
When I tried to log in to the CLI with the admin account it had me reset the password which I did. And now when
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at java.net.Socket.connect(Socket.java:538)
at java.net.Socket.<init>(Socket.java:434)
at java.net.Socket.<init>(Socket.java:244)
at com.cisco.ca.ss.lcm.adminshell.client.ShellClient.main(ShellClient.java:51)
Error occured: could not connect to the database server.
Please make sure
Connection to
07-25-2017 04:02 PM
Hi Phillip,
Admin shell is one the last service to start. This generally happens when attempting to login to as the CSPC is still spinning up. Best practice is to allow a few moments post restart/reboot before logging into the admin shell.
If you have root access, can you please extract and share the following files (since you have started via GUI, I have idea where it is stuck):
/opt/LCM/logs/install
/opt/LCM/logs/apply
Output will help to investigate further.
Supriya
01-23-2018 09:10 AM
Hello Supriya,
Can you please advise, as i do not have the root or collectorlogin access, and i had the same issue, tried to login into CSPC collector ver 2.5. It asked for password reset. Did that, after that i was not able to login into the cspc, as the connection terminated immediately with the below error input.
Please advise what should i do?
======== error which occurred after login with the new pass=========
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at com.cisco.ca.ss.adminshell.client.ShellClient.main(ShellClient.java:63)
01-23-2018 12:48 PM
Hello Gagan,
We ask that a new discussion is started to ensure visibility for our experts and for tracking purposes. You will receive a timely response.
Cheers,
Cheri
08-02-2017 12:28 PM
I am having the same problem. Please provide instructions for the CLI upgrade. The link below is the configuration guide for a new appliance.
Thanks, George
08-02-2017 12:35 PM
Hi George,
I would request you to start separate post with your current collector version to avoid confusion. You will be answered in timely manners by experts.
Supriya
