Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
117
Beginner
Multiple Inventories - Same collector
Is it possible to have the collector report to 2 separate inventory segments in the services portal? Or is it only possible to do the segmentation via the web portal?
1 ACCEPTED SOLUTION
Highlighted
Re: Multiple Inventories - Same collector
Unfortunately this is not possible with CSPC, the only current method is by using segment creations on the SNTC Portal.
Thank you,
Jarrett
1 REPLY 1
Highlighted
Thank you,
Jarrett
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
