03-15-2017 12:45 PM
Hello all,
I'm new to the smartnet services, I used to have smartnet for our nexus 3048 switch but didn't get renewed after expiring, I signed up and was able to login but I get a message that I don't have an active contract associated with my account, do I contact my reseller to get a new contract, how to I move fwd with getting my switch under support again.
thanks in advanced
carlo
Solved! Go to Solution.
03-16-2017 07:01 AM
Hello Carlo,
To get a devices added to a SmartNet contract or a new SmartNet contract set up you would need to speak to your Cisco Partner. They will be able to manage this for you as you do not buy direct from Cisco.
Regards, Tim
03-15-2017 01:43 PM
Check your mp !
03-15-2017 02:23 PM
thanks for the reply, if you mean management portal, I can login but I get this message that I don't have an active contract associated with a smartnet account, I contacted CDW and they don't seem to have an idea what I need, can I buy the contract directly from Cisco
carlo
03-16-2017 07:01 AM
Hello Carlo,
Regards, Tim
03-16-2017 09:39 AM
Thanks for the reply, I'm now working with a reseller to get this straightened out.
