Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
287
Highlighted
Beginner
No data is displayed in any SNTC view post change to v4.0
Hi folks,
I'm not getting any view to load/show any data post the change to SNTC 4.0
Every view appears stuck with the loading icon (cg-busy-default-spinner) displayed.
The only view that shows any content is: Dashboards > Smart Net Total Care – ‘Community pane’ (Announcements & Discussions)
This issue is found to be common across all browsers and all users.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: No data is displayed in any SNTC view post change to v4.0
Hi Graham,
We’re pleased to hear that reports are populating.  The issue was a blocking process remaining from the recent maintenance and quickly addressed.
Going forward, the new processing introduced with 4.0 is designed to address several reported concerns, including stuck uploads which we are aware you have experienced.
Cheers,
Cheri
3 REPLIES 3
Dear Graham,
Could you please try now accessing the reports and keep us posted if you still face the issue .
Pamela
Beginner
Hi Pamela,
Yes, data is now being populated with the views. May I enquire as to what was the problem was?
Rgds,
Graham
Hi Graham,
Cheers,
Cheri
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
