Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
121
Highlighted
Beginner
Not Covered report does not show reason why
Within the services portal when I view the "Not Covered" report under "Contracts" 100% of the devices show "Review Needed" under the "Reason Not Covered" column.
I need to be able to discern between which device are not covered due to end of support status and which are not covered due to contract expiration.
I am certain there used to be a way to see this information.  Any advice?
Everyone's tags (3)
2 REPLIES 2
Re: Not Covered report does not show reason why
The Not Covered report only tells which devices are not covered and need review. You may find the Custom Inventory report useful, specifically the coverage start, coverage end, contact status, and contract number columns.
Once you have identified the reason it is not covered you can revisit the report and update the coverage action.
https://www.cisco.com/c/en/us/support/docs/services/sntc/portal_user_guide.html
Beginner
Within the "Custom inventory" it looks like HW LDOS is akin to End of Support date. I think this is a good start.
Thank you
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
