Pluggables in ASR-920 have incorrect product ID in the SNTC portal reports
We have some SFP+ ZR optics in our ASR-920 routers.  All of them show up as Xenpaks in the SNTC portal inventory.
Anybody else having this issue?
Actual equipment - PID = SFP-10G-ZR-S
Reported equipment - PID = XENPAK-10GB-ZR
10 Replies 10
Results from SNMP walk show correct PID for the 2 SFP+ ZR optics in this ASR-920:
c:\>snmpwalk.exe -r:[removed] -c:[removed] -os:.1.3.6.1.2.1.47.1.1.1.1.11.1 -op:.1.3.6.1.2.1.47.1.1.1.1.14.1
OID=.1.3.6.1.2.1.47.1.1.1.1.11.696, Type=OctetString, Value=FL[removed]25
OID=.1.3.6.1.2.1.47.1.1.1.1.12.696, Type=OctetString, Value=CISCO-FUJITSU
OID=.1.3.6.1.2.1.47.1.1.1.1.13.696, Type=OctetString, Value=SFP-10G-ZR-S
OID=.1.3.6.1.2.1.47.1.1.1.1.11.710, Type=OctetString, Value=FL[removed]35
OID=.1.3.6.1.2.1.47.1.1.1.1.12.710, Type=OctetString, Value=CISCO-FUJITSU
OID=.1.3.6.1.2.1.47.1.1.1.1.13.710, Type=OctetString, Value=SFP-10G-ZR-S
Screenshot of SNTC portal attached showing incorrect PID listed as XENPAK-10GB-ZR
Chris Camplejohn
Can you private message me an example serial number so I can investigate?
Chris - PM sent.  Thank you sir!
-ben
Thank you for the data and bringing this to our attention. This has been corrected and will be in production by tonight. If you send another upload from CSPC to SNTC tomorrow, then the data should be corrected once that upload is processed. Please let us know if that resolves the issue.
Thanks, Chris.  Our uploads are scheduled for Monday mornings.  I'll check on it on 7/29.  I really appreciated the quick turnaround on this.  I'll be sure to update this thread with what we see.
Thanks again!
-ben
Chris - the product ID is correct now, but we are still getting an alert for LDOS over 12 month and within 24 months.  The hyperlink provided via SNTC is still for the Xenpak.
Great to hear that the product ID is fixed. There is an open bug that the development team is working on for these types of “stale” EOL records left behind. I’ll see if they can run the clean-up script on your account in the meantime.
Thanks for the update, Chris.  We'll continue to monitor and let you know when we see it resolved.
Looks like it is all fixed now.  I hadn't checked on it in a while.  Thanks for the help!
