Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
319
Highlighted
Beginner
Problems with pulling info from WLC 5520
Hi.
I have successfully gotten the CSPC to communicate and pull data from routers and switches in our environment up to the portal.
However, I have been unable to get the collector to pull anything from our 5520 wireless lan controller. I have tried snmpv2 and v3 with the same result. I can ping the controller from the CSPC.
The error I get is "Device Unreachable or Incorrect SNMP Credentials."
I know the SNMPv3 user is setup correctly on the WLC because we use Prime with the same credentials and are able to connect just fine
Any ideas?
Fred
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: Problems with pulling info from WLC 5520
Is there a firewall or ACL in the path between CSPC & the WLC?
5 REPLIES 5
Hey antnsgl,
I see in post https://community.cisco.com/t5/smart-net-total-care-portal-and/snmp-walk/m-p/3901675#M11687 that you are trying to access root for snmpwalk command.  That will assist with your issue here to troubleshoot polling the WLC 5520.
First, we need to get into root access.  Based on the other post "The only account I have for the collector is the initial one I setup when installing the collector.", im guessing you have the 'admin' login for the CLI of the collector correct?  If so, we can run 'pwdreset collectorlogin 90' and 'pwdreset root 90' from the admin access.  These two commands will generate passwords for the respective logins.  Please save these in your records for future use.
Once the passwords are created, then try running the snmpwalk commands seen below.
SNMPv2c:
snmpwalk -v 2c -c ROCommunityString DeviceIPAddress
SNMPv3:
snmpwalk -v 3 -u Username -l SecurityLevel (AuthPriv/AuthNoPriv) -a AuthProtocol (SHA/MD5) -A AuthPasswd -x EncryptionProtocol (DES/AES) -X EncryptionPasswd DeviceIPAddress
Justin
Beginner
Thanks, Justin.
I will give that a try and let you know the results.
Beginner
Hi.
I have run the snmpwalk successfully from the collector to the WLC. I get an error that says "No response from x.x.x.x"
I enabled the debugs on the WLC and I can see the packets from the collector, here is the conversation:
*SNMPTask: Aug 02 07:30:12.158: [SA] SNMPD: Packet from: X.X.X.X:39051, in_packet_len = 42
*SNMPTask: Aug 02 07:30:12.158: [SA] SNMPD: calling srDoSnmp.
*SNMPTask: Aug 02 07:30:12.158: [SA] SNMPD: received get-next pdu
*SNMPTask: Aug 02 07:30:12.158: [SA] SNMPD:calling do_response
*SNMPTask: Aug 02 07:30:12.158: [SA] Searching for next instance of sysDescr
*SNMPTask: Aug 02 07:30:12.158: [SA] SNMPD: Sending SNMP packet to X.X.X.X:39051, out_packet_len = 61
*SNMPTask: Aug 02 07:30:13.159: [SA] SNMPD: Packet from: X.X.X.X:39051, in_packet_len = 42
*SNMPTask: Aug 02 07:30:13.159: [SA] SNMPD: calling srDoSnmp.
*SNMPTask: Aug 02 07:30:13.159: [SA] SNMPD: received get-next pdu
*SNMPTask: Aug 02 07:30:13.159: [SA] SNMPD:calling do_response
*SNMPTask: Aug 02 07:30:13.159: [SA] Searching for next instance of sysDescr
*SNMPTask: Aug 02 07:30:13.159: [SA] SNMPD: Sending SNMP packet to X.X.X.X:39051, out_packet_len = 61
*SNMPTask: Aug 02 07:30:13.630: [SA] SNMPD: Packet from: X.X.X.X:32450, in_packet_len = 234
*SNMPTask: Aug 02 07:30:13.630: [SA] SNMPD: calling srDoSnmp.
*SNMPTask: Aug 02 07:30:13.630: [SA] SNMPD: received get pdu
*SNMPTask: Aug 02 07:30:13.630: [SA] SNMPD:calling do_response
*SNMPTask: Aug 02 07:30:13.630: [SA] Searching for requested instance of bsnRogueAPAirespaceAPWepMode
*SNMPTask: Aug 02 07:30:13.630: [SA] Searching for requested instance of bsnRogueAPAirespaceAPWpaMode
*SNMPTask: Aug 02 07:30:13.630: [SA] Searching for requested instance of cLRogueAPDetectingAPWpa2Mode
*SNMPTask: Aug 02 07:30:14.161: [SA] SNMPD: Packet from: X.X.X.X:39051, in_packet_len = 42
*SNMPTask: Aug 02 07:30:14.161: [SA] SNMPD: calling srDoSnmp.
*SNMPTask: Aug 02 07:30:14.161: [SA] SNMPD: received get-next pdu
*SNMPTask: Aug 02 07:30:14.161: [SA] SNMPD:calling do_response
*SNMPTask: Aug 02 07:30:14.161: [SA] Searching for next instance of sysDescr
*SNMPTask: Aug 02 07:30:14.161: [SA] SNMPD: Sending SNMP packet to X.X.X.X:39051, out_packet_len = 61
Beginner
There is not but there must have been something going on with routing. I ended up changing the IP of the collector to reside on the same subnet as the WLC and everything started working.
Thanks for your help.
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
