"Developer Over Rate" response when accessing sn2info API
Srihas
When trying to access the API:
GET https://api.cisco.com/sn2info/v2/coverage/status/serial_numbers/<serial_number>
Response:
Status Code: 403
Body: <h1>Developer Over Rate</h1>
Is there any limit on the number of requests to access this API?
Please suggest solution to evade this issue.
Jarrett Pomeroy
You can view your rate of usage on the API Console here -> https://apiconsole.cisco.com/apps/myapis
SN2Info API is set to 1000 calls per day by default. You may want to look at including multiple serial numbers in a single API call (you can include up to 75) to reduce the total number of calls needed by your application.
Thank you,
Jarrett
Hi Jarrett,
Is there a way to increase the no. of API calls per day from 1000 to maximum applicable for my application?
Srihas
