05-31-2016 02:01 PM
I have been able to edit lines of devices under the Service Coverage menu, but for some reason when I select the Equipment Type subset "POWER_SUPPLY" I cannot update. I do everything the same, selecting "All (248)" lines of devices and then receiving the "Bulk Update" message, however the reason never updates. I have tried three separate times hours apart from each other and have waited for it to update but nothing. Please help.
06-07-2016 03:26 PM
Thank you for your message. This may be a bug. We'll check and get back to you.
06-07-2016 03:31 PM
Yes, the individual updates work, but selecting two or more fails.
Thank you for looking into this!
07-21-2016 03:36 PM
Daniel - I will reach out to you on email to see if you're still having this problem.
thanks,
Teresa
07-22-2016 06:53 AM
A defect has been created to capture this issue.
Please refer the bug #CSCva59820.
Sanjay
06-10-2016 09:19 AM
There is most definitely an issue with the Bulk Update, as selecting 9 devices for edit works correctly, but as soon as 10 are selected and Bulk Update is activated, the mod fails. Thank you
06-07-2016 03:29 PM
The bulk update "should" work, however, can you tell us if this works when you select/check items individually and then perform the update?
Bobby
