Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
494
sarahaknight
Beginner
Serial number not in SNTC
Serial numbers are not showing up in the SNTC. I do see the serial numbers in the CSPC and can confirm this data is collected via the "ENTITY-MIB_entPhysical" dataset in the collection profile. Currently running version 2.8.1.5 and this is a fairly recent issue.
5 REPLIES 5
sarahaknight
Beginner
Should note that I am using the default "SNTC" Collection Profile and it's linked to my upload profile.
Hi user,
Please share below in private message:
Could you please share customer company name, inventory and questioned device SNs that were not showing on portal? Please share couple of SN along with ip and hostname in private message. Please share screenshot of what you see under dataset for ENTITY-MIB_entPhysical.
Supriya
Shared and am able to see serial numbers in the STNC via the "Collected SN" field versus "Serial Number" as a workaround. Thank you!
Please refer to bug CSCvq89357. This is quite new bug and will be visible soon with detail.
Supriya
I received your private message.
Community front page is update on given issue. Here is the detail on that. Fix will be available on August 20th.
https://community.cisco.com/t5/smart-services-documents/update-on-sntc-portal-reports-with-missing-serial-numbers/ta-p/3909439
Supriya
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
