05-08-2018 08:29 AM - edited 03-12-2019 07:47 AM
Is there a way to reset the portal to the defaults?
05-08-2018 08:49 AM
Hi Darrel,
You are able to delete inventories, if that is what you mean. That will give you a fresh view of your installed base. Please see the Inventory Deletion section of the SNTC User Guide for details.
Cheers,
Cheri
05-08-2018 09:02 AM
Hello Cheri,
So deleting all the existing inventories will bring the portal back to the initial setup?
I am also deploying the CSPC collector and are having challenges with the uploads.
Would you be able to help me with doing an export of the collector file for me to manually perform the upload?
05-10-2018 09:37 AM
05-16-2018 06:03 AM
05-16-2018 06:37 AM
On later releases of the CSPC, you can also use the quick link buttons and select "Collected Data" to access the report.
Thank you,
Jarrett
