10-09-2015 10:08 AM
Does SmartNet Total Care also support Cisco UCS?
If yes, which inventory features are supported for Cisco UCS? For example is it possible to see the different blades or disks within the inventory?
Thanks already now and best regards
Thomas
10-09-2015 10:15 AM
You should be able to see the blades, but the disks likely will not be there. You need to ensure the collector is managing the Fabric Interconnect, since it is the FI that reports the inventory of the UCSM.
12-01-2015 12:43 PM
how do you view blades? my collector is managing all fabric interconnects but no blades/hosts are found
12-07-2015 06:42 PM
I have exactly the same issue
12-07-2015 09:18 PM
Hi Galvin,
I've just posted above the list of Cisco UCS supported today in SNTC. Please check.
Pavan
12-07-2015 09:16 PM
Hi Thomas,
Following Cisco UCS PIDs are supported by SNTC as of today.
For verifying any other PIDs support status, please use the SNTC PID-checker available at, https://supportforums.cisco.com/document/12098436/sntc-pid-checker
PID | Product Family | Display |
C260-BASE-2646 | Cisco UCS C-Series Rack-Mount Servers | Supported in SNTC |
N10-E0060 | UCS 6100 Series Modules | Supported in SNTC |
N10-E0060= | UCS 6100 Series Modules | Supported in SNTC |
N10-E0080 | UCS 6100 Series Modules | Supported in SNTC |
N10-E0080= | UCS 6100 Series Modules | Supported in SNTC |
N10-E0440 | UCS 6100 Series Modules | Supported in SNTC |
N10-E0600 | UCS 6100 Series Modules | Supported in SNTC |
N10-PAC1-550W | Cisco UCS 6100 Series Power Supplies | Supported in SNTC |
N10-PAC1-550W= | Cisco UCS 6100 Series Power Supplies | Supported in SNTC |
N10-PAC2-750W | Cisco UCS 6100 Series Power Supplies | Supported in SNTC |
N10-PAC2-750W= | Cisco UCS 6100 Series Power Supplies | Supported in SNTC |
N10-S6100 | Cisco UCS 6100 Series Fabric Interconnects | Supported in SNTC |
N10-S6100= | Cisco UCS 6100 Series Fabric Interconnects | Supported in SNTC |
N10-S6100-UPG | Cisco UCS 6100 Series Fabric Interconnects | Supported in SNTC |
N10-S6200 | Cisco UCS 6100 Series Fabric Interconnects | Supported in SNTC |
N10-S6200= | Cisco UCS 6100 Series Fabric Interconnects | Supported in SNTC |
N20-AC0002 | UCS Adapters | Supported in SNTC |
N20-AE0002 | UCS Adapters | Supported in SNTC |
N20-AE0102 | UCS Adapters | Supported in SNTC |
N20-AQ0002 | UCS Adapters | Supported in SNTC |
N20-B6620-1 | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6620-1= | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6620-1-UPG | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6620-2 | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6620-2D | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6620-2-UPG | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6625-1 | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6625-1= | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6625-1-UPG | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6625-2 | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6625-2-UPG | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6730-1 | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6730-1= | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-B6730-1-UPG | Cisco UCS B-Series Blade Servers | Supported in SNTC |
N20-C6508 | Cisco UCS 5100 Series Blade Server Chassis | Supported in SNTC |
N20-C6508-UPG | Cisco UCS 5100 Series Blade Server Chassis | Supported in SNTC |
N20-FAN5 | UCS Fans | Supported in SNTC |
N20-I6584 | UCS 2100 Series Fabric Extenders | Supported in SNTC |
N20-PAC5-2500W | UCS Power Supplies | Supported in SNTC |
N20-PAC5-2500W= | UCS Power Supplies | Supported in SNTC |
N2XX-ACPCI01 | UCS Adapters | Supported in SNTC |
N2XX-ACPCI01= | UCS Adapters | Supported in SNTC |
R200-1120402W | Cisco UCS C-Series Rack-Mount Servers | Supported in SNTC |
R210-2121605W | Cisco UCS C-Series Rack-Mount Servers | Supported in SNTC |
R460-4640810 | Cisco UCS C-Series Rack-Mount Servers | Supported in SNTC |
UCSB-B200-M3 | Cisco UCS B-Series Blade Servers | Supported in SNTC |
UCSB-MLOM-40G-01 | UCS Adapters | Supported in SNTC |
UCSB-MLOM-40G-01= | UCS Adapters | Supported in SNTC |
UCSB-PSU-2500ACPL | UCS Power Supplies | Supported in SNTC |
UCSC-C220-M3L | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCSC-C220-M3S | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCSC-C22-M3L | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCSC-C22-M3S | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCSC-C240-M3L | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCSC-C240-M3S | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCSC-C24-M3L | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCSC-C24-M3S | Cisco UCS Fabric Interconnects | Supported in SNTC |
UCS-E140S-M1/K9 | UCS Modules | Supported in SNTC |
UCS-E160DP-M1/K9 | UCS Modules | Supported in SNTC |
UCS-FI-6248UP | Cisco UCS 6200 Series Fabric Interconnects | Supported in SNTC |
UCS-FI-6248UP= | Cisco UCS 6200 Series Fabric Interconnects | Supported in SNTC |
UCS-FI-6248UP-UPG | Cisco UCS 6200 Series Fabric Interconnects | Supported in SNTC |
UCS-FI-6296UP | Cisco UCS 6200 Series Fabric Interconnects | Supported in SNTC |
UCS-FI-6296UP= | Cisco UCS 6200 Series Fabric Interconnects | Supported in SNTC |
UCS-FI-E16UP= | UCS Modules | Supported in SNTC |
UCS-IOM-2204XP= | UCS 2100 Series Fabric Extenders | Supported in SNTC |
UCS-PSU-6248UP-AC | UCS Power Supplies | Supported in SNTC |
UCS-PSU-6296UP-AC | UCS Power Supplies | Supported in SNTC |
UCS-VIC-M82-8P | UCS Adapters | Supported in SNTC |
Best Regards,
Pavan
