07-12-2018 06:27 AM - edited 03-12-2019 07:52 AM
I am trying to generate the consolidated report using the Cisco supplied Smart Service Upload and Reporting macro. I can load the macro spreadsheet ok (Macros are enabled in Excel). The Inventory report import works OK, however, when doing the Product Alert import, after around 20 seconds it fails with 'Microsoft Visual Basic - Run-time error '9': - Subscript out of range'
Further investigation, by opening the individual files downloaded from the portal appears to point to an issue with the Alerts report. When opening in Excel it throws an error saying that the file may have errors, it then goes on to try and repair it with the following error log -
<?xml version="1.0" encoding="UTF-8" standalone="true"?>
-<recoveryLog xmlns="http://schemas.openxmlformats.org/spreadsheetml/2006/main">
<logFileName>error111280_01.xml</logFileName>
<summary>Errors were detected in file '\\****.local\****2$\*****5$\****.****\profile\Desktop\Report\2018-07-12_Alerts.xlsm'</summary>
-<removedParts summary="Following is a list of removed parts:">
<removedPart>Replaced Part: /xl/worksheets/sheet4.xml part with XML error. Illegal xml character. Line 7, column 281.</removedPart>
</removedParts>
</recoveryLog>
Can you please advise.
Andy
07-12-2018 02:08 PM
07-13-2018 07:59 AM
07-13-2018 08:04 AM
07-13-2018 08:39 AM
Hi Andrew,
Thank you for bringing the issue to our attention. We'll investigate further and get this fixed.
Cheers,
Cheri
07-17-2018 01:25 PM - edited 07-17-2018 01:26 PM
Hi Andrew,
We've been able to identify the root cause of the issue. Specifically, All instances of Field Notice FN70223 appear to contain an invalid character within the generated report which causes the error in Microsoft Excel.
https://www.cisco.com/c/en/us/support/docs/field-notices/702/fn70223.html
We've created a CDET for this issue as well which should be visible shortly:
CSCvk39954
