Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
287
Beginner
smartnet and microphone hardware replacement
Does anyone know if smartnet covers the microphones that are part of the Cisco MX300 telepresence system or is just the core unit covered?
1 ACCEPTED SOLUTION
Re: smartnet and microphone hardware replacement
Hi Jonathan,
I am  not 100% sure how the replacement would be managed but I think we would swap the microphone.  If you open a TAC case using the SmartNet contract number and the serial number of the Codec the TAC can confirm.  When opening the case state that you need a replacement for the microphone.
Regards, Tim
6 REPLIES 6
You can put the CTS-MX300-UNIT= under SmartNet.  This includes the MX300 Gen 2 integrated codec, LCD, camera, speaker,  and microphone.  I believe the Smart net Total Care portal will only display the Codec.
Regards, Tim
Beginner
The systems are on smartNet but we have the small microphones from the MX300 system that stopped functioning.  Will SmartNet replace those?
Hi Jonathan,
Regards, Tim
Beginner
Thanks Tim,
I have six microphones that would need replacing, would I need a separate TAC case for each?
Hi Jonathan,
I would just open one case as the issues are all related.
Regards, Tim
Highlighted
Hi Jonathan,
Regards, Tim
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
