07-17-2017 02:24 PM
Under view devices
Solved! Go to Solution.
07-17-2017 02:41 PM
CSPC no longer shows serial numbers in UI starting in version 2.7. There is a way to enable it, but it impacts de-duplication logic and would not be recommended.
07-18-2017 08:00 AM
Can you send me a PM (see instructions) to let me know the company name and inventory name you are looking at. I think I have the right one and I see your File imports from 2016, but I also see 7 or 8 uploads from July 17th. Some are successful and some still in queue. Even though serial numbers aren't seen in CSPC UI, they will be in the upload and show in SNTC Portal.
07-25-2017 11:50 AM
Hello Jarret
Is there a way to
(See
07-17-2017 02:41 PM
07-17-2017 06:57 PM
Aloha Chris Camplejohn
Ok, so how do I
07-18-2017 07:57 AM
Hello BuddyAllison
I can see that your uploads from the CSPC have successfully reached the SNTC Portal. From your screenshot, you may currently only have the "CSV" Inventory name selected in the top left drop down menu. Can you please see if you can view the CSPC Uploads after selecting the top left "pencil" icon and selecting "All Inventory And Segments" for the Inventory name?
Thank you,
Jarrett
07-21-2017 05:39 PM
07-25-2017 11:50 AM
07-18-2017 08:00 AM
07-21-2017 05:27 PM
Hello Chris
Can we see the devices in SNTC Portal? still only see olds devices?
08-06-2019 04:15 AM
Hi how do i enable this feature as other smart collects have the serails on 2.7 and 2.8 but one doesnt
08-06-2019 01:05 PM
Hey patrickroberts,
Are you referring to seeing SNs within the CSPC GUI? If so, 'Settings' -> 'Discovery Settings' -> Switch 'Serial Number Duplicate Check' to Yes.
Justin
08-06-2019 11:38 PM
08-07-2019 07:36 AM
Hey patrickroberts,
By 'backend' are you referring to the SNTC Portal? If so, ensure you are running a 'Collection/Inventory' job and not just an upload job. To do so, go to the CSPC GUI -> 'Management' -> 'Collect Data' -> Select the default SNTC account and run job. DO NOT push an upload after, the default collection profile will export an upload upon completion. Let me know if SNs still blank after.
Justin
12-02-2020 02:20 AM
Hi Sorry for the delay been on other works with all that is going on...
Still not getting hte correct info at the back end SNTC portal .. i always do a SNTC push but still same issue..
also in inventory Delta section i do a snapshot is see equipment added 52 but deleted 62 ? on the same date
could this be due to the smart colelct being on a hyper V platform ?
12-08-2020 01:44 PM
Hey patrickroberts,
To confirm, you are only running the collection job with the 'SNTC' collection profile and not using an additional upload profile to export to the portal?
Private message me the Company/Inventory names on the portal for me to take a look.
Justin
