04-12-2019 05:12 AM
Hello.
I perform manual uploads (csv opt.) to SNTC, but noticed that system generates no alerts (PSIRT/Field Notices/...) for devices marked cat-OS as SoftwareType.
Solved! Go to Solution.
04-12-2019 07:15 AM
04-12-2019 05:53 AM
CatOS is long past EOL. What did you include in the CSV upload?
04-12-2019 06:23 AM
Unfortunately, several devices still exist in the infrastructure and awaits replacement/upgrade process. I guess that recommendation says to remove them from import file?
04-12-2019 07:15 AM
