Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
268
Highlighted
SNTC not show SN (Serial Number)
In my CSCP I see the SN of devices, but in the SNTC portal the SN is not showed.
 - I am use the CSCP version 2.8
 - My setting to check duplicate SN is: Settings > Discovery Settings > Serial Number Duplicate Check = Yes
What could be the problem?
Everton
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: SNTC not show SN (Serial Number)
Hi Everton,
Can you click on Modify Collection Profile for your custom Collection Profile <> Profile Details tab and type this into the service name box smartnet_total_care and see if you can run a new upload to see if your SN gets processed.
Thanks!
5 REPLIES 5
Highlighted
Hi Everton,
Do you know if you're uploading with the Collection Profile or an Upload Profile? If you are using an Upload Profile, best practice would be to go under Settings <> Manage Upload Profiles <> Select the Upload Profile <> Select Single Collection Profile radio button and make sure the Upload Inventory box is checked.
Thanks!
Highlighted
Beginner
Highlighted
Hi @Dannis Bounvilay , thanks by reply.
I have two Collection Profile. One of them I believe to be a default profile because I can not edit - Profile name: SNTC.
Another one was created by me and I defined the informations that are collected
What I not understand is that in my Upload Profile, I can only choose the SNTC Collection profile.
Asked your question, I did upload with the Upload Profile below.
Everton
Hi Everton,
Thanks!
Highlighted
Thank you for your time and assistance. I did the change suggested and after this, all works as I need.
Everton
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
