Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
173
SNTC not show SN (Serial Number)
In my CSCP I see the SN of devices, but in the SNTC portal the SN is not showed.
 - I am use the CSCP version 2.8
 - My setting to check duplicate SN is: Settings > Discovery Settings > Serial Number Duplicate Check = Yes
What could be the problem?
Everton
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: SNTC not show SN (Serial Number)
Hi Everton,
Can you click on Modify Collection Profile for your custom Collection Profile <> Profile Details tab and type this into the service name box smartnet_total_care and see if you can run a new upload to see if your SN gets processed.
Thanks!
5 REPLIES 5
Hi Everton,
Do you know if you're uploading with the Collection Profile or an Upload Profile? If you are using an Upload Profile, best practice would be to go under Settings <> Manage Upload Profiles <> Select the Upload Profile <> Select Single Collection Profile radio button and make sure the Upload Inventory box is checked.
Thanks!
Beginner
Hi @Dannis Bounvilay , thanks by reply.
I have two Collection Profile. One of them I believe to be a default profile because I can not edit - Profile name: SNTC.
Another one was created by me and I defined the informations that are collected
What I not understand is that in my Upload Profile, I can only choose the SNTC Collection profile.
Asked your question, I did upload with the Upload Profile below.
Everton
Hi Everton,
Thanks!
Highlighted
Thank you for your time and assistance. I did the change suggested and after this, all works as I need.
Everton
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
