ā01-02-2019 04:53 AM
Customer has registered on SNTC portal and confirmed his access sucessfully on Dec, 16 and now, when he tries to access SNTC Portal page, he is directed to SNTC Register page.
Could you help us, please?
Luciano.
Solved! Go to Solution.
ā01-02-2019 10:28 AM
I have checked the customer account status and set up looks good.
You may want to take a look at Portal Guide to see how to go about setting up an initial inventory.
Once an upload has been received and processed, the portal will start to display all the options and reports available.
ā01-02-2019 06:01 AM
Please send the CCO of the customer via private message for troubleshooting the access issue.
ā01-02-2019 06:17 AM
Thank you for sharing the details. The registration information was not updated at SNTC end, fix has been applied. Please ask customer to retry accessing the portal and let us know in case of any issues.
Suchita
ā01-02-2019 07:54 AM
ā01-09-2019 09:31 AM
This doesn't work for me. I'm not "directed to the Get Started page upon login" where I might "import your inventory through a CSV file import, or automate device collection through a collector" instead I get sent to a page suggesting "You do not currently have access to Smart Services Connection." from there I can click register "https://www.cisco.com/web/smartservices/sntc.html" which restarts the loop. if I register it says I am already registered and redirects to "You do not currently have access to Smart Services Connection." if I sign in it goes straight to "You do not currently have access to Smart Services Connection."
ā01-09-2019 09:51 AM
Can you please test your access again and confirm if it is still not loading the portal?
Brandon
ā01-09-2019 10:03 AM
