SNTC Portal - most menu options are missing
I am currently logged into SNTC, however, I am not able to see the status of any uploads or any other menus in the portal. What I can see appears to be very restricted?
Library - Get Started
Administration - All Collectors
There are no other options showing?
Is this a permissions issue? CSPC has successfully completed an upload.
Andrew
adias
Assuming the company you are connecting to is BxxxxxxxY XX LD an upload has just occurred today.  however it seems that only a discovery was performed and then an upload.  A discovery is not sufficient to bring inventory data to the portal. and if you do an "UPLOAD" just after a discovery without a collection it will just bring that minimal information.
You do have some restrictions for modifying and viewing several areas since you are assigned as a "user" not an administrator on SNTC portal. You should  change that since you are the DA for your company on https://cdceb.cloudapps.cisco.com/csam and you can modify your role to customer administrator
A discovery learns minimal information about the device and place them on the managed device list.
The you will need to schedule a 'COLLECTION PROFILE " and run it.  Additionally on SNTC a "UPLOAD PROFILE" is not necessary because it is redundant.  the COLLECTION PROFILE already has a feature to upload the data to the portal at the end of its process
