Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
473
Tomasz Banasik
SNTC processing discrepancy
Hi all
My customer who is manually uploading data from CSPC to the portal gets a bit frustrated by the number of devices collected by collector and those which appear on the portal. The difference is 71:37.
Is there any way to check why we see so big difference?
Thanks in advance.
Tomasz
3 REPLIES 3
mburley
Beginner
Is it 71 devices from the collector and 37 on the portal or 37 devices from the collector and 71 on the portal?
Burleyman
It's 71 on collector but just 37 on the portal.
Tomasz
So the customer gets 71 devices shown in the CSPC collector and then manually uploads the file to the portal and only sees 37. correct? If this is true then I would open a TAC case because something with the file formatting or the portal itself maybe missing data to allow the other devices to show up there. Maybe the devices are listed as belonging to another customer, I have seen that happen.
Mike
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
