06-13-2019 07:15 AM
I went to login to the Total Care demo portal to use to pitch to a customer. When I used the login credentials that had worked in the past; I got a error message that said invalid credentials.
Were the login credentials to the demo portal intentionally changed?
Thanks in advance for your help!
Doug Hudson
Business Development Manager
Solved! Go to Solution.
06-13-2019 08:56 AM
Yes, the login password was changed on June 12. There is an updated Demo script available with the new login.
Here's the link to the Demo script: https://www.cisco.com/c/dam/en/us/support/docs/services/sntc/sntc-demo-script-for-partner-use.pdf
06-13-2019 08:56 AM
