SSL web cert for my Cisco CSP collector- instruction not very good please help
tjjackson
Below are the instructions I found uploading a web cert to my collector,
they are not very clear. - the first command does not run .
I have a valid CA cert. Are there any more clear instructions anywhere.?
Common Services Platform Collector User Guide
Appendix G Uploading Valid SSL Certificate
/opt/cisco/ss/adminshell/applications/CSPC/jreinstall/bin/keytool
-list -v -keystore $CSPCHOME/webui/tomcat/conf/cspcgxt
Enter keystore password:cspcgxt
Now the CSPC keystore has only 1 Alias,
Keystore type: JKS
Keystore provider: SUN Your keystore contains 1 entry
Alias name: 1
Changing Alias name to tomcat (this step is optional) using the command below.
-changealias -alias 1 -destalias tomcat -keystore
Enter keystore password: cspcgxt
Step 7 Verifying the Alias name change,
Keystore type: JKS
Keystore provider: SUN. Your keystore contains 1 entry
Alias name: tomcat
Step 8 Restart the CSPC service using below command
# service cspc restart
Step 9 Verify the uploaded SSL certificate in a browser below screen appears
brawall
Are you receiving any sort of error when trying to add the cert? At which step of the user guide are you starting at to do the import? I will do some testing on my side and provide an update.
Thank you,
Brandon
