Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
651
tjjackson
Beginner
SSL web cert for my Cisco CSP collector- instruction not very good please help
Below are the instructions I found uploading a web cert to my collector,
they are not very clear. - the first command does not run .
I have a valid CA cert. Are there any more clear instructions anywhere.?
Common Services Platform Collector User Guide
Appendix G Uploading Valid SSL Certificate
/opt/cisco/ss/adminshell/applications/CSPC/jreinstall/bin/keytool
-list -v -keystore $CSPCHOME/webui/tomcat/conf/cspcgxt
Enter keystore password:cspcgxt
Now the CSPC keystore has only 1 Alias,
Keystore type: JKS
Keystore provider: SUN Your keystore contains 1 entry
Alias name: 1
Changing Alias name to tomcat (this step is optional) using the command below.
-changealias -alias 1 -destalias tomcat -keystore
Enter keystore password: cspcgxt
Step 7 Verifying the Alias name change,
Keystore type: JKS
Keystore provider: SUN. Your keystore contains 1 entry
Alias name: tomcat
Step 8 Restart the CSPC service using below command
# service cspc restart
Step 9 Verify the uploaded SSL certificate in a browser below screen appears
1 REPLY 1
brawall
Are you receiving any sort of error when trying to add the cert? At which step of the user guide are you starting at to do the import? I will do some testing on my side and provide an update.
Thank you,
Brandon
Create
Recognize Your Peers
Right-rail
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
