12-17-2018 09:01 AM
Anyone know the status of a fix for the bug where the portal shows duplicate devices and or old devices that may have been RMA'd?
12-17-2018 10:45 AM
Can you share the bug ID please? If you are referring to CSCvm90277 then we do not have an update yet, just that it has been assigned and is being worked on.
12-17-2018 11:08 AM
That sounds similar, but the bug we were alerted to by a Cisco contact was back in early November, so hard to believe it was just entered on 12/10. Will attempt to locate the #.
12-17-2018 01:04 PM
That bug was opened on 10/15 and was last updated on 12/7
