Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
134
Highlighted
Beginner
support in malta
Hi All,
I would like to know if the cisco smartnet 24x7x4 onsite is available in the country Malta.
https://en.wikipedia.org/wiki/Malta
Sony
1 ACCEPTED SOLUTION
Re: support in malta
You can determine availability by checking the Service Availability Matrix.
https://samccx.cloudapps.cisco.com/apidc/sam/search.do
4 REPLIES 4
Hall of Fame Community Legend
If you purchased SmartNet then it will be covered.
Beginner
thanks for the feedback. will check the link
Sony - check the Service Availability Matrix. It helps to have the postal code and product family available.https://samccx.cloudapps.cisco.com/apidc/sam/search.do
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
