02-12-2020 11:20 PM - edited 02-23-2020 08:41 PM
Afternoon,
Just trying to register for the collector trial version but receiving error "Trial license cannot be applied as there is no connectivity to Cisco Backend".
I'm using Common Service platform collector 2.8
can someone please help?
Update
we have configured DNS and proxy details which was successful the first time but had to re-install CSPC OVA again because the connection was not routing through the proxy settings that we set and could not go back to the Install screen to amend the settings and test to see why it’s not routing through the proxy.
When trying to configure the DNS and proxy for the second time it was failed (maybe the Config already registered with Cisco Collector database.…not sure) but when I saved the settings with failed configuration. It accepted the setting anyway and the connection seems to be going out even though it failed verification but just that it’s still not routing through the proxy.
So now there are 2 issues:
Solved! Go to Solution.
02-27-2020 07:19 AM
Hello Please be so kind and try one more time now.. You should be able to do it now. If not let me know
02-24-2020 06:22 PM - edited 02-26-2020 03:39 PM
Perhaps there is not a problem with the connectivity itself. but there is a problem with the trial certificate creation..
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs70380
Is there a reason you not using an actual valid SNTC certificate for this account ?
02-24-2020 09:32 PM
Hi @adias
Thought just trying a trial before the real thing but anyways, just tried to generate the file and getting this error message "Entitlement file generation failed. Please try again. If the issue persists, find help in the community."
02-26-2020 03:33 PM
Hi @adias ,
Any updates on this issue?
Can you generate the certificate and send to my CCID perhaps?
02-26-2020 03:41 PM
Unfortunately there is not work around for the trial license at this time. you can follow resolution by following the bug at
My suggestion is to go ahead and follow the self onboarding process and get a full license since there is no cost involved in this process
02-26-2020 03:48 PM
Hi @adias,
I'm not trying to using trial version anymore.
I'm trying to generate the full license but getting error " entitlement file generation failed. Please try again, if the issue persists, find help in the community" (see attached)
Can you possible try to generate the full license and send it to me?
every time I tried it failed, no matter what browser I used.
02-26-2020 04:34 PM
Let me give look and get back to you in a bit
02-27-2020 07:19 AM
02-27-2020 03:20 PM
02-27-2020 03:28 PM
Good thank you for your patience and glad it worked now
