10-07-2019 01:30 PM
Trying to upgrade our Cisco CSPC to the latest version. The upgrade icon is not working in the GUI. Tried downloading from CLI and am getting the following error:
admin# upgrade
Version Description
sp-30.1.1-6-0-lnx64 Collector patch to upgrade to CSPC 2.8.1.6.
sp-30.0.4-9-0-lnx64 Collector patch to upgrade to CSPC 2.7.4.9
Download and apply of a package can take a while.
It is recommended to schedule the upgrade.
Do you want to continue [y|n] ?y
Please enter the version to upgrade :sp-30.1.1-6-0-lnx64
Do you want to continue with download and apply [y|n] ?y
Connection to Software Download Server will use User Id xxxx@xxxxx.com
In order to download software, please indicate that you have read and agree
to be bound by the Cisco End User License Agreement which can be viewed at
http://www.cisco.com/en/US/docs/general/warranty/English/EU1KEN_.html
Accept License Agreement (y|n)? y
Attempting to download the requested package.....sp-30.1.1-6-0-lnx64
execute % Error occured while executing command
admin#
10-08-2019 10:51 AM
HI User,
What is your current version of collector? you can find that using command 'show version -d' (with CLI login use 'admin' to collector). As well, I would recommend to use manual upgrade process using below guide which has step-by-step to upgrade collector.
Supriya
10-08-2019 11:22 AM
Here's what version we are running:
admin# show version -d
Build-name : Collection Platform Software 2.7.3
Package-type : ServicePack
Version : sp-30.0.3-0-0-lnx64
Component : CSPC Base
Version : 2.7.3
Package-type : JeOS
Version : jeos-30.0.3-0-lnx64
Component : AdminShell
Version : 1.6
Component : LCM
Version : 1.6
Component : CASP
Version : 2.7.3
Component : ConcsoTgw
Version : 1.7.0
Component : Hardened CentOS
Version : 6.8 patch#0
10-08-2019 12:35 PM
Hi User,
Please check page 19 and Chapter 3. Please do let me know if you have any question.
supriya
10-09-2019 07:10 AM
Supriya,
I am seeing this error when I try to unzip the file. Is this a concern?
[root@localhost opt]# unzip collector_2.8.1.4_Build-16.zip
Archive: collector_2.8.1.4_Build-16.zip
error [collector_2.8.1.4_Build-16.zip]: missing 60182 bytes in zipfile
(attempting to process anyway)
error [collector_2.8.1.4_Build-16.zip]: attempt to seek before beginning of zipfile
(please check that you have transferred or created the zipfile in the
appropriate BINARY mode and that you have compiled UnZip properly)
(attempting to re-compensate)
creating: collector_2.8.1.4_Build-16/
inflating: collector_2.8.1.4_Build-16/install.sh
extracting: collector_2.8.1.4_Build-16/jeos-30.1.1-4-lnx64.zip bad CRC f93aea52 (should be 8fbc6459)
file #4: bad zipfile offset (local header sig): 795280818
Curt
10-09-2019 07:36 AM
Supriya,
I was able to resolve the FTP issue
Curt
10-09-2019 09:34 AM
Supriya,
For some odd reason, after I did the ./install.sh JeOS jeos-30.1.1-4-lnx64.zip command; I lost connectivity to collectorlogin and root. I had to reset the passwords to gain access again. Is that normal?
Curt
10-09-2019 11:10 AM
Supriya,
Success!! Please advise on next steps
Build-name : Collection Platform Software 2.8.1.4
Version : sp-30.1.1-4-0-lnx64
Version : 2.8.1.4
Package-type : JeOS
Version : jeos-30.1.1-4-lnx64
Version : 1.9.1
Component : LCM
Version : 1.9.1
Component : CASP
Version : 2.8.1.4
Version : 1.7.7
Version : 6.10 patch#0
10-09-2019 03:26 PM
Latest image can be downloaded using below link:
https://software.cisco.com/download/home/286312935/type/286312958/release/2.8.1.6
Supriya
