Unable to login to SNTC portal page
skc455
I have problems getting my team members login to the SNTC portal, as a DA I gave permissions and also assigned roles. However, they still can't access. When they try to request access it tells they already have permissions and redirects to the main page, but when the page is displayed it says "You do not currently have access to SNTC" .
Thanks for the details. Your colleagues should now be able to access the SNTC portal as expected.
Justin Sprake
It sounds as though there may be an issue syncing their assigned statuses, if possible, please send the following details to me in a private message:
  • Company Name (as it appears within CSAM)
  • CCO of current DA
  • CCO IDs of concerned assignees
Sent private message with the requested info Justin, thank you for looking into this.
Worked as expected, thank you for your support on this Justin. What was the issue?
