Unable to run reports and other issues in SNTC portal
JSM92
I've been increasingly having trouble navigating around in the portal.  Some screen will never load, some give the "you are not authorized" error.  Using Chrome in both regular and incognito modes as well as IE.  Cleared cache to no avail.  I can usually click around in the menu and them come back to what I wanted and it will work, but not today.  Very frustrating.
Jarrett Pomeroy
SNTC Portal Issues Resolved
The SNTC portal has been experiencing slowness and report display issues for the past several days. The engineering team has identified the root cause and corrected the issue.
All systems are back to normal."
You can subscribe to status information about the SNTC portal and its components and choose email or text message notification and the specific component type on the operational dashboard. Use this URL to subscribe: http://sntc-status.cisco.com.
We’re sorry for any inconvenience the temporary degradation in service may have caused you.
Jarrett Pomeroy
