Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
828
Highlighted
Beginner
Unable to Upload & Unable to Update from CSP-C.
Hi everyone,
I have an issue where the customer is trying to Collect but they are being greeted with the error below.
In addition, they are also having an issue where they cannot update their Collector through the Software updater in the Collector itself as they are being given this output despite continually logging in with a fresh CCOID Login to the Server Connection. (The Server Connection login is confirmed to be successful at least.)
Any advice on how to proceed? Thank you!
1 ACCEPTED SOLUTION
Highlighted
These are 2 different distinct problems :
FIRST PROBLEM: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg80140
Please request customer to connect to the user collectorlogin then su to root and execute the following commands
From root run the following commands in order:
sed -i ':a;N;$!ba;s/file/#file/1' /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/run.sh
sed -i 's/nettools-upload.cisco.com/72.163.7.113/g' /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
service concsotgw restart
After the above commands run, try running an upload again and see if has same error message., if still not working send me the output of the commands below in Private
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
SECOND PROBLEM.
We are finding that there may be some global connectivity issues with the www.cisco.com servers which is required for the access.  We still be investigating the problem but at present we do not have a root cause and/or solution
The priority bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvr54360
If there is an upgrade available and it is necessary to upgrade , until it is resolved it must be done manually.
5 REPLIES 5
Highlighted
SECOND PROBLEM.
Highlighted
The root run commands were what resolved this for the customer. Thank you.
Highlighted
This resolved our issue. Thank you!
Highlighted
i am having the same issue. Above did not resolve this.
Highlighted
Can you please create a new community post with details about your issue.
Thanks!
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
