Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
838
Highlighted
Beginner
Upgrade to CSPC 2.8 stuck on "Apply-in-progress"
My CSPC is running version 2.7.4.3.  I attempted to run the upgrade to 2.8 from the Software Updates page.  Status is now stuck on "Apply-in-progess".  Rebooting the appliance did not help.  How can I clear/cancel/stop this current upgrade so that I can then run the upgrade from the CLI?
9 REPLIES 9
Highlighted
Do you have access to the admin CLI account?
Taylor
Highlighted
Hi, yes I have full root access to the virtual appliance.
Highlighted
Highlighted
Hi, I did that already, but it did't actually do anything. Still running on 2.7.4.3. Here is the end of the 'apply' log file. Can we get the server out of the "Apply-in-progress" status?
[collectorlogin@cmmql0093 ~]$ tail -f /opt/LCM/logs/apply
[Mon Oct 29 16:17:35 CDT 2018] --Component--LCM--LCM |Component |JeOS |1.8 |LCM component |1540491340--jeos-30.1.0-0-lnx64--
[Mon Oct 29 16:17:35 CDT 2018] else block of status update
[Mon Oct 29 16:17:35 CDT 2018] update version--1.8---LCM---Component-------
[Mon Oct 29 16:17:36 CDT 2018] --Component--Hardened CentOS--Hardened CentOS |Component |JeOS |6.10 patch#0 |Hardened CentOS |1540491341--jeos-30.1.0-0-lnx64--
[Mon Oct 29 16:17:36 CDT 2018] else block of status update
[Mon Oct 29 16:17:36 CDT 2018] update version--6.10 patch#0---Hardened CentOS---Component-------
[Mon Oct 29 16:17:37 CDT 2018] --JeOS--JeOS--JeOS |JeOS | |jeos-30.1.0-0-lnx64 |Appliance Base Package patch update |1540491342--jeos-30.1.0-0-lnx64--
[Mon Oct 29 16:17:37 CDT 2018] else block of status update
[Mon Oct 29 16:17:37 CDT 2018] update version--jeos-30.1.0-0-lnx64---JeOS---JeOS-------
[Mon Oct 29 16:17:37 CDT 2018] status db updation completed
Highlighted
Can you post the output of the following from root?
#cd /opt/LCM/tmp
#ls -alrth
Highlighted
Hi, here is the output.
[root@cmmql0093 ~]# cd /opt/LCM/tmp
[root@cmmql0093 tmp]# ls -alrth
total 1.8G
drwxr-xr-x. 9 casuser casusers 4.0K Oct 25 11:19 ..
-rw-r--r--. 1 casuser casusers 1.6G Oct 25 12:50 sp-30.1.0-0-0-lnx64-package.zip
-rw-r--r--. 1 root root 161M Oct 26 12:27 sp-30.0.4-3-0-lnx64-package.zip
drwxr-xr-x. 2 casuser casusers 4.0K Oct 26 12:38 .
Highlighted
From /opt/LCM/tmp run the following commands in order.
#Unzip sp-30.1.0-0-0-lnx64-package.zip
#nohup /opt/LCM/bin/lcmagent-apply.tcl SP /opt/LCM/tmp/ sp-30.1.0-0-0-lnx64.zip &
Highlighted
Hi ,
A small correction in command to install the patch -
#/opt/LCM/bin/lcmagent-apply.tcl SP /opt/LCM/tmp/sp-30.1.0-0-0-lnx64.zip &
Highlighted
That worked, thank you. My collector is now on 2.8.
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
