01-29-2020 10:29 AM
Hi there
My customer has a problem with upload.
We already tryed to change the certificate (generate a new CSP -C entitlement) and run the command below with the old certificate and the new certificate:
sed -i ':a;N;$!ba;s/file/#file/1' /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/run.sh
sed -i 's/nettools-upload.cisco.com/72.163.7.113/g' /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
service concsotgw restart
But the problem still the same and there is no firewall rule impeding the traffic.
Can somebody help me, please?
01-29-2020 10:33 AM
It appears you are affected by CSCvq97104, therefore our recommendation is that you upgrade the CSPC to the latest version 2.8.1.7 or 2.7.4.10 depending on your base version.
https://software.cisco.com/download/home/286312935/type/286312958/release/2.8.1.7
03-02-2020 05:55 AM
Even I am Facing the Same Issue Tried:
03-02-2020 06:58 AM
Please always open a new post... "Internal Server Error" is a generic error the solution will depend on the more specific logs from the collector and workaround /solutions will vary
03-06-2020 06:11 AM
03-06-2020 06:44 AM
open a new post
