Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
405
Beginner
Upload Processing shows Inventory Source as 'System Replay'
It is observed for many of our distinct inventories (12 out of 16) since the change to SNTC 4.0, several uploaded inventories are listed as being System Replays?  This appears to have started about 14th November.
Can this please be investigated.
KR,
Graham
1 ACCEPTED SOLUTION
Re: Upload Processing shows Inventory Source as 'System Replay'
Hi Graham,
Fixed the issue and started functioning as expected.
Sreejith
4 REPLIES 4
 Hi User,
Thanks for reaching out to Cisco.
After the SNTC 4.0 release, old uploads were migrated to new systems by re-playing from backend. That is the reason its showing as System replay. It is excepted behaviour only.
Please let me know if you have any queries.
regards
Sreejith Mungath
Everyone's tags (1)
Beginner
Hello Sreejith,
I state in my query that these are 'uploaded inventories' and the issue is observed post about the14th November; these are not replays of existing inventories that were expected due to the upgrade.
This is an issue with new uploads (both direct from collector and as manual file upload) being listed as their Inventory Source being ‘System Replay’ and not the correct source as either ‘Collector Upload’ or ‘File Import’ as applicable.
Hi Graham,
We found the same with few other customers also and we are working on it.
Will let you know once it fixed.
Sreejith Mungath.
Hi Graham,
Sreejith
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
