09-04-2017 02:12 AM - edited 03-12-2019 07:29 AM
Hi folks,
I have an inventory upload that is reported as still 'in progress' since Sep 1, 2017 3:26 PM BST.
As no issues are reported within the http://sntc-status.cisco.com/ page, could I ask if this can be investigated?
Full details (customer/inventory) will be supplied on request.
Graham
Solved! Go to Solution.
09-04-2017 10:53 PM
09-04-2017 10:53 PM
09-05-2017 02:15 AM
Hi, yes I see that the one that was received at "Sep 1, 2017 8:40 PM" was processed OK, but would you be able to comment on why the one that was 'stuck', uploaded on "Sep 1, 2017 3:03 PM" subsequently 'failed'?
Rgds,
Graham
09-06-2017 02:56 AM
Hi Graham,
Thank you for reaching out to us .
Due to one of the module during upload processing got impacted by a bug(not every upload will fall under same category) and thus support team monitoring the uploads processing proactively took action to make it failed( observing the progress of upload is not expected) and reprocessed the same file which got completed successfully. We have long-term solution in place to overcome this issue but in between to make the upload process successfully this workaround implemented.
Pamela
09-07-2017 12:14 PM
Hi Graham,
Please confirm you are now seeing the upload in the portal. If there is nothing further, please mark this as solved.
Thanks!
Cheri
09-08-2017 04:29 AM
Hi Cheri,
I think I follow Pamala's explanation...
Is there any estimate as to when the 'long-term' solution will be implemented?
Thanks & regards,
Graham
09-08-2017 08:08 AM - edited 09-08-2017 08:20 AM
Hi Graham,
I will get the bug information and post here for you to follow it.
Cheers,
Cheri
09-11-2017 02:28 AM
