03-19-2019 10:07 AM
I've did discovery and collect data at SNTC application but in the Portal the status about this collect is Received, I did another collect and the latest change to status bypassed. Am I doing something wrong or forgot any step?
Thanks.
Solved! Go to Solution.
03-19-2019 10:50 AM
Hello Raphael,
You are good. The upload processing is experiencing slight delay in processing of uploads, you may have to give it some time for the system to complete the processing.
When the latest upload came in, the previous upload that was waiting in the queue was bypassed, the system will now process the most recent upload and the status should change to success once the processing is complete.
Suchita
03-19-2019 10:50 AM
Hello Raphael,
Suchita
03-21-2019 09:53 AM
Hello Suchita Shewale,
Thanks for your support and complete explanation about the process.
I had to wait more than 24h to get Success status. But now it seems to be all collection there.
Raphael Pulchera
03-19-2019 10:51 AM
You will see the status of BYPASSED if you issue multiple within a short time frame before other uploads are finished processing. The Portal will process the latest most upload you have sent. If you see it's in RECEIVED state, it means it may be sitting in the queue to get processed.
Thank you,
Jarrett
03-20-2019 12:51 AM
How long should we expect to wait? I have uploads that are in progress for 24hrs now. I need the data ......
03-20-2019 08:46 AM - edited 03-20-2019 08:48 AM
In most cases, this will be completed within 24 hours but is subject to the quantity of devices as well as the overall size size of the upload data itself. Initiating new uploads will not ensure that the data is processed more quickly, but rather restart the processing cycle.
03-20-2019 10:55 AM
Thanks for the answer. The uploaded processed around that time frame. Any idea when this issue will be fixed?
