Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
222
Beginner
Web UI Login
Unable to login in to the web UI of CSCP version 2.7
I have a ssh admin, root and collectorlogin passwords and can login via the cli.
I've tried both admin and Admin123 with the Admin#123 password to try and login to the web ui but no luck.
Can I reset the admin web UI passowrd from the cli?  or add a new web ui user via the cli?
4 REPLIES 4
Re: Web UI Login
Hey rklda,
I will private message you a workaround to try.
Justin
Highlighted
Beginner
Re: Web UI Login
That worked, Thanks!
Beginner
Re: Web UI Login
Can you share what was done to resolve this? This is the exact scenario I find myself in. Thank you
Re: Web UI Login
Hey bryan.perina,
Unfortunately, this was version specific and the CSPC has been updated so that this workaround no longer takes effect.
Currently, the only methods for forgotten passwords are to answer the security questions or if an email was entered in the Email Settings, a new OTP can be sent to the email to use as a password reset.
Justin
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
