01-04-2015 09:56 PM
This is a direct question from customer. He has multiple IP addresses configured on a device, and asked A) how the collector determines which IP address to collect, as well as B) through which port it is collected.
TIA,
John (EPM for Korea and ASEAN)
Solved! Go to Solution.
01-05-2015 11:20 PM
All the IP addresses configured on the device would be listed. There is an interface summary also possible which lists all interfaces and ip addresses.In order to discover network devices and collect the data from the devices, you need to enter the credentials first. part of that is adding IP address ranges. This will help collect on a device. Th various ports used for SNMP query ( 161) and https upload (443) are listed in the security whitepaper. Hope this helps
-Sanjeev
01-05-2015 11:20 PM
-Sanjeev
01-07-2015 12:57 AM
Hi Sanjeev,
Thanks very much for your response. I understand how the CSPC collects information when a Seed File is used, but what about in case of IP ranges? Is it whatever port responds first to the ICMP and SNMP ping? or is there a set order?
Thanks again,
John
01-07-2015 02:34 PM
Hi John
we are an SNMP shop. so its pretty much SNMP. ICMP is used only as a fallback when SNMP fails to check if the IP is reachable.
-sanjeev
