i have 2 pc Cisco 3560-48ps-s switch all them not poe works delivery
173
Beginner
we need support for why not delivery support POE asll ports
what migh be issue, i guess hardware but not sure
what must i do IOS software change or some replacment companent change ?
thanks
Nihat KOSOVA
9 Comments
Hall of Fame Community Legend
Post the complete output to the following commands: 1. sh version; and 2. sh power in
Beginner
Switch#sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
Image text-base: 0x00003000, data-base: 0x01100000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
Switch uptime is 1 hour, 0 minutes
System image file is "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin"
cisco WS-C3560-48PS (PowerPC405) processor (revision Q0) with 122880K/8184K bytes of memory.
Processor board ID FDO1238Y3ZB
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
--More--
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:23:5D:7C:F0:80
Motherboard assembly number : 73-9676-14
Power supply part number : 341-0029-05
Motherboard serial number : FDO12380EVB
Power supply serial number : DTN123242N0
Model revision number : Q0
Motherboard revision number : A0
Model number : WS-C3560-48PS-S
System serial number : FDO1238Y3ZB
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : FDO123617EK
Top Assembly Part Number : 800-25859-04
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : COMU210ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
--More--  * 1 52 WS-C3560-48PS 12.2(35)SE5 C3560-IPBASE-M
Switch#sh powe
Switch#sh power in
Switch#sh power inline
Available:0.0(w) Used:0.0(w) Remaining:0.0(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Fa0/2 auto off 0.0 n/a n/a 15.4
Fa0/3 auto off 0.0 n/a n/a 15.4
Fa0/4 auto off 0.0 n/a n/a 15.4
Fa0/5 auto off 0.0 n/a n/a 15.4
Fa0/6 auto off 0.0 n/a n/a 15.4
Fa0/7 auto off 0.0 n/a n/a 15.4
Fa0/8 auto off 0.0 n/a n/a 15.4
Fa0/9 auto off 0.0 n/a n/a 15.4
Fa0/10 auto off 0.0 n/a n/a 15.4
Fa0/11 auto off 0.0 n/a n/a 15.4
Fa0/12 auto off 0.0 n/a n/a 15.4
Fa0/13 auto off 0.0 n/a n/a 15.4
Fa0/14 auto off 0.0 n/a n/a 15.4
Fa0/15 auto off 0.0 n/a n/a 15.4
Fa0/16 auto off 0.0 n/a n/a 15.4
Fa0/17 auto off 0.0 n/a n/a 15.4
Fa0/18 auto off 0.0 n/a n/a 15.4
Fa0/19 auto off 0.0 n/a n/a 15.4
--More--  Interface Admin Oper Power Device Class Max
(Watts)
Fa0/20 auto off 0.0 n/a n/a 15.4
Fa0/21 auto off 0.0 n/a n/a 15.4
Fa0/22 auto off 0.0 n/a n/a 15.4
Fa0/23 auto off 0.0 n/a n/a 15.4
Fa0/24 auto off 0.0 n/a n/a 15.4
Fa0/25 auto off 0.0 n/a n/a 15.4
Fa0/26 auto off 0.0 n/a n/a 15.4
Fa0/27 auto off 0.0 n/a n/a 15.4
Fa0/28 auto off 0.0 n/a n/a 15.4
Fa0/29 auto off 0.0 n/a n/a 15.4
Fa0/30 auto off 0.0 n/a n/a 15.4
Fa0/31 auto off 0.0 n/a n/a 15.4
Fa0/32 auto off 0.0 n/a n/a 15.4
Fa0/33 auto off 0.0 n/a n/a 15.4
Fa0/34 auto off 0.0 n/a n/a 15.4
Fa0/35 auto off 0.0 n/a n/a 15.4
Fa0/36 auto off 0.0 n/a n/a 15.4
Fa0/37 auto off 0.0 n/a n/a 15.4
Fa0/38 auto off 0.0 n/a n/a 15.4
(Watts)
Fa0/39 auto off 0.0 n/a n/a 15.4
Fa0/40 auto off 0.0 n/a n/a 15.4
Fa0/41 auto off 0.0 n/a n/a 15.4
Fa0/42 auto off 0.0 n/a n/a 15.4
Fa0/43 auto off 0.0 n/a n/a 15.4
Fa0/44 auto off 0.0 n/a n/a 15.4
Fa0/45 auto off 0.0 n/a n/a 15.4
Fa0/46 auto off 0.0 n/a n/a 15.4
Fa0/47 auto off 0.0 n/a n/a 15.4
Fa0/48 auto off 0.0 n/a n/a 15.4
Switch#
Says PoE is supported.
Beginner
Solution ?
Can you try upgrading the firmware of the switch to something more recent, like 12.2(55)SE12?
Beginner
Yes ,i have tired but noting,
ok thans for full help
Post the complete output to the following commands: 1. sh version; 2. sh inventory; and 3. sh post
Beginner
All them below ,
sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:04 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Switch uptime is 1 minute
System image file is "flash:c3560-ipbasek9-mz.122-55.SE12.bin"
--More--  to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560-48PS (PowerPC405) processor (revision Q0) with 131072K bytes of memory.
--More--  Model revision number : Q0
Version ID : V05
* 1 52 WS-C3560-48PS 12.2(55)SE12 C3560-IPBASEK9-M
Configuration register is 0xF
Switch#sh post
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Found inline power controller write failure, inst 1
POST: Inline Power Controller Tests : End, Status Failed
POST: Inline Power feature is disabled on this switch
--More--  POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Switch# sh inver
Switch# sh inver
Switch# sh inventory ?
WORD Entity name
raw Show every entity in the container hierarchy
| Output modifiers
<cr>
NAME: "1", DESCR: "WS-C3560-48PS"
PID: WS-C3560-48PS-S , VID: V05 , SN: FDO1238Y3ZB
Switch#
POST: Found inline power controller write failure, inst 1 POST: Inline Power Controller Tests : End, Status Failed PoE module is dead.
Content for Community-Ad
August's Community Spotlight Awards
