Best 3rd Party wireless solution witth DNAC -SDA
michael crane
Community Member
What would be one of the best 3rd party wireless solutions to use with DNAC-SDA????  Thanks!
KevinMuller
Level 3
Level 3
If you want to an Over-the-Top architecture, any brand can fit with SDA as Access points will be considered as "normal" endpoints. For SDA-Wireless enabled architecture, you have to stick with Cisco.
KevinMuller
Level 3
Level 3
