6509 non-e chassis
Mukesh Kumar
Level 3
Level 3
I want to install 10gig line cards on 6509 non-e chassis. Can anyone suggest me which model of line card i have to install?
Does that line card model support my current SUP engine "WS-SUP720-3BXL"?
How many line card this SUP engine can support?
Is my current sup engine doesn't support 16-Port 10 Gigabit Ethernet Copper Module Line card?
But why do you want to install a WS-X6716-10T?  It's not as if your supervisor card can push 160Gbps line rate.  The most a Sup720 can push is 40 Gbps (per slot) so you have an over-subscription rate of a whooping 4:1.
5 Replies 5
Leo Laohoo
If you're going to have Sup720, which has a 40 Gbps backplane, then the only line card that is line-rate is WS-X6704-10G
Thanks for the information.
Mukesh Kumar
Network Engineer
Spooster IT Services
Thanks for this information Leo Laohoo.
Mukesh Kumar
Network Engineer
Thank you very much for rating our posts, Mukesh.  cheeky
