Add additional switches to Fabric
s.nicholls
Hi we have purchased 2 9506 Directors whic we want to dd to ir existing fabric which consists of 2 MDS 9222i switches. As the new switches are running 5.0.1 code and the MDS 4.1 (3a) I presume that I will need to upgrade the existing switches as well as Fabric Manager.
The first question I have is around the upgrade. If i put the latest code on will there be any disruption at all?
The second question is how can i make the new switch the principal switch with minimal downtime?
Steve
Vu Phan
Hello Nicholls,
-     Upgrade old switch MDS9222i is a ISSU non-disruptive process
-     you wiil also need to upgrade Fabric Manager to 5.0.1 the same Release number as the switch or higher. In this case, 5.0.1 or higher. Preferred higher FM release
-     Assuming the configured domain ID left as default "preferred" on all switches
-     you can change switch priority to 1 or 2 to assume principle and restart fcdomain non-disruptive.
ex:
On the switch to be principle
conf t
fcdomain priority 2 vsan xx
fcdomain restart vsan xx
