955
kbyrd
Explorer
After Sup1 to Sup2 upgrade on 9509, strange behavior for TACACS+ and DIR BOOTFLASH:
I upgraded a 9509 from dual sup1s running 3.3(1c) to dual sup2s running 3.3(1c). I later upgraded to 4.2(7a). we did this in order to get support for a new DS-X9248-96K9 module.
After replacing the sup1s with sup2s, everything appeared fine with two exceptions:
1) when we telnet'd, we would fail AAA/tacacs authentication. Console using local username is fine,
MDS Switch
login: validuser
Password:
Login incorrect
Digging deeper, there were no configuration changes for AAA nor tacacs. We see failed attempts in the ACS server log. However:
C9509-DC-1# test aaa server tacacs+ 10.1.14.8 validuser validpassword
user has been authenticated
C9509-DC-1# test aaa server tacacs+ 10.1.14.8 validuser invalidpassword
user has failed authentication
...with the corresponding passed and failed logs in the ACS server.
Also, show tacacs-server statistics shows all passed attempts.
C9509-DC-1# show tacacs-server statistics 10.1.14.8
Server is not monitored
Authentication Statistics
        failed transactions: 0
        sucessfull transactions: 46
        requests sent: 46
        requests timed out: 0
        responses with no matching requests: 0
        responses not processed: 0
        responses containing errors: 0
Authorization Statistics
        sucessfull transactions: 14
        requests sent: 14
Accounting Statistics
        sucessfull transactions: 0
        requests sent: 0
Any Ideas:
2) DIR BOOTFLASH://SUP-LOCAL/ works, but DIR BOOTFLASH://SUP-STANDBY/ does not.
From the standby module, DIR BOOTFLASH://SUP-LOCAL/ works fine.
C9509-DC-1# dir bootflash://sup-local/
      16384     Dec 16 21:04:10 1916  lost+found/
   16604160     Jan 04 16:20:36 1917  m9500-sf2ek9-kickstart-mz.3.3.1c.bin
   21764608     Jan 04 16:23:54 1917  m9500-sf2ek9-kickstart-mz.4.2.7a.bin
   78718938     Jan 04 16:21:15 1917  m9500-sf2ek9-mz.3.3.1c.bin
  103575233     Jan 04 16:25:46 1917  m9500-sf2ek9-mz.4.2.7a.bin
       2168     Jan 04 16:55:24 1917  mts.log
Usage for bootflash://sup-local
  283611136 bytes used
  619552768 bytes free
  903163904 bytes total
C9509-DC-1# dir bootflash://sup-standby/
Input/output error
C9509-DC-1# attach module 6
Attaching to module 6 ...
To exit type 'exit', to abort type '$.'
---snip out the copywrite info----
C9509-DC-1(standby)# dir bootflash:
        315     Jan 04 16:28:16 1917  MDS20071129112452322.lic
      49152     Jan 04 16:46:30 1917  lost+found/
   16604160     Jan 04 15:51:05 1917  m9500-sf2ek9-kickstart-mz.3.3.1c.bin
   78718938     Jan 04 15:49:28 1917  m9500-sf2ek9-mz.3.3.1c.bin
       1484     Jan 26 17:11:39 1970  mts.log
  283648000 bytes used
  619515904 bytes free
Any ideas?
Thanks.
6 REPLIES 6
bfeeny
Beginner
Just to clarify, are you saying you see failed attempts in the TACACS log when you enter valid passwords?  Or are you just saying you see failed attempts when you purposely fail authentication?
In the ACS server's passed and failed authentication logs, I see the corresponding Pass and Fail when I do the TEST AAA command from the MDS command line.
When I actually try to telnet and login, I see failed attempts in the ACS server log. That's what is so strange. The reason is either invalid password and one time I saw "user locked out" from the local ACS directory. Then I would run the test command from the command line and all works normaly.
Thanks for your follow-up...
By any chance do you have "aaa authentication login mschap enable" configured?
I do not:
aaa group server tacacs+ VTYACS
aaa group server radius radius
aaa authentication login default group VTYACS local
aaa authentication login console local
aaa authentication login error-enable
Strange indeed, but what does your TACACS group look like vs. what you are typing when you do the test aaa command?
This is the test:
C9509-DC-1# test aaa group VTYACS username goodpassword
C9509-DC-1# test aaa group VTYACS username badpassword
C9509-DC-1#
tacacs-server host 10.1.14.8 key 7 "glxJq09"
tacacs-server host 10.32.14.8 key 7 "glxJq09"
    server 10.1.14.8
    server 10.32.14.8
