ARP issue on Nexus 5596(l3)
Ben Alex
Need help badly.
I have 2 nexus 5596 in VPC mode. Each one has a blade switch connected to it.
blade1--Nx1---Nx2----Blade2
Nx1 and Nx2 can ping management address on Blade2
Nx1 and NX2 cannot ping blade1. Nx1 see blade1 in cdp nei table.
Nx1 shows Blade1 incomplete in ip arp table. Config has been verified 10 times and cannot see anything.
From the management consile onf Blade 1 I can ping NX1.
I noticed a lof on ARP incomplete in the ARP table
Note: Peer gateway enabled on both .
This is driving me crazy
Thanks for helping.
JPavonM
Have you solved this issue?
We have the same scenario and one cluster is not pinging between them, but each one can reach the gateway and the outside.
Kind regards
