I have tested the 5420 in iSCSI routing and iSCSI transparent routing mode and I have some question regarding security:
a) about WWPns.
Is it possible to determine what WWPN will be assigned to a given IP host when it connects to the AS6420?, it seems that any IP hosts can be assigned any given WWPN (out of the 31 WWPNs available!), so, How am I supposed to implement zoning in my intelligent controller?, is there any way to define what WWPN will be assigned or used by an IP host?? is it always random and not configurable??, if so, how am I suposed to implement security zoning if I can't narrow down the WWPN used by a given IP host??
b) Does the 5420(40) fully support the AAA model?? it seems to me that it only uses the authentication part, what about the Authorization and Accounting bits??
Thanks for any comments about it.
