09-04-2008 07:23 AM
Do these come with the Gigabit Ethernet G-bic as standard?
09-04-2008 08:02 AM
Apparantly not. I managed to find out...
for anybody else that's interested.
09-11-2008 02:32 AM
Sounds like you found out that the Gigabit Ethernet SFPs are not provided with the card. The main reason is that you might want to use long wave SFPs for the connection if distance is an issue, versus the standard short wave SFPs.
