Check firmware support between cisco 9706 and 9222i for config port group
Hong Cong
Hi all,
Please help me!
My customer want configuring port group between 2 san director ( MDS 9706 and MDS 9222i)
Can you help check firmware compatiblity between MDS 9706 and MDS9222i
Information MDS 9706:
Software
BIOS: version 3.1.0
kickstart: version 6.2(9)
system: version 6.2(9)
BIOS compile time: 02/27/2013
kickstart image file is: bootflash:///m9700-sf3ek9-kickstart-mz.6.2.9.bin
kickstart compile time: 6/3/2014 1:00:00 [07/11/2014 17:49:48]
system image file is: bootflash:///m9700-sf3ek9-mz.6.2.9.bin
system compile time: 6/3/2014 1:00:00 [07/11/2014 19:44:38]
Module : DS-X9448-768K9
Information MDS 9222i:
Software
BIOS: version 1.0.19
loader: version N/A
kickstart: version 5.0(1a)
system: version 5.0(1a)
BIOS compile time: 02/01/10
kickstart image file is: bootflash:/m9200-s2ek9-kickstart-mz.5.0.1a.bin
kickstart compile time: 12/25/2020 12:00:00 [02/21/2010 19:43:11]
system image file is: bootflash:/m9200-s2ek9-mz.5.0.1a.bin
system compile time: 2/2/2010 17:00:00 [02/21/2010 20:39:33]
FC module: DS-X9248-48K9
Walter Dey
Hi I assume you mean port-channel ?
For the MDS 9706 DS-X9448-768K9 each port is wirerate; no port sharing !
https://www.cisco.com/c/en/us/products/collateral/storage-networking/mds-9700-series-multilayer-directors/data_sheet_c78-727817.html
This per-slot bandwidth is twice the bandwidth needed to support a 48-port 16-Gbps Fibre Channel module at full line rate.
The MDS 9222i  DS-X9248-48K9 module has 4 ports of 8 Gbps ; I believe there is no port sharing between this 4 8 Gbps ports.
Cisco MDS 9000 Family 1/2/4/8-Gbps 4/44-Port Host-Optimized FC Module
Walter Dey
Dear Walter Dey,
Thanks for support!
You can set bandwidth for each port on DS-X9448-768K9 from 16G to 8G?
And using 4 port witch bandwidth is 8G for port-channel?
Best Regards,
yes of course !
