Cisco 64Gb SPF and HPE Virtual Connect SE 32Gb connection issues
twigs
Hi!
I have and HP Synergy blade chassis with HPE Virtual Connect SE 32Gb with MPO to 4x LC Breakout Multi-Mode Fiber Optic Cable.
During testing of different hardware prior to going into production with new MDS switches, I found problem with this combination.
I have connected the HP VC and configured only two of four MPO uplinks as 16Gb, connected 2 Optic Cables to 2 Cisco 64Gb SFP, the ports are in up state and negotiate as 16Gb, If I change in the HP VC the configuration of the ports to 32Gb, I can see in the MDS switch port status as notConnected.
What could be the cause of this behavior?
Jason Mooney
HPE is aware of this issue.  The issue comes down to the 100Gb QSFP to quad 32Gb SFPs have a problem.  While negotiating 32Gb FC speeds, the HPE SFP suddenly reduces it's speed to 16Gb when communicating back to the Cisco 64Gb interfaces.  This is caused by the HPE hardware expecting a Training Complete before it successfully finishes the negotiation.
The MDS isn't seeing any primatives or FC data on the line. You can use slot X show hardware internal fcmac port Y port-logs for interface fcX/Y and see that SNR:0.0 which indicates the MDS isn't receiving signal.  In this particular case we can see the fibre channel training frames agreed on 32Gb, but then the remote side droped to 16Gb.
`slot 3 show hardware internal fcmac port 1 port-logs`
========= FCP Port#1 Internal Port platform Log ==========
MMDDYY HHMMSS usecs   Event                  DATA
041525 144012 314194  SERDES_RX_STATE        ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE004804
041525 144012 313839  TTS_SYNC               Pass:1 val:0x104 RX:32G TX:16G TF.CS 0x L[08,70] R[C0,40]
041525 144012 282959  RX_LANE_ENABLE         Lane:0x31 SN:0x835 TX:0xC RX:0x10
041525 144012 282696  SERDES_DELAY           Reg val:4
041525 144012 282271  SERDES_RX_SPEED        32G
041525 144012 282271  SERDES_TTS_RX          32G SN:0x835 Lane:0x11
This is an example of the Signal to Noise Ration being zero.
041525 144012 609444  SERDES_RX_DFE      0.00,0.00,0.00,2.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00
041525 144012 609190  SERDES_RX_STATE    ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE006835
041525 144012 608827  TTS_SYNC           Pass:1 val:0x104 RX:32G TX:32G TF.CS 0x L[C8,70] R[C0,40]
041525 144012 578502  SERDES_RX_DFE      0.00,0.00,0.00,2.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00
041525 144012 578178  SERDES_RX_STATE    ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE00681B
041525 144012 577809  TTS_SYNC           Pass:1 val:0x104 RX:32G TX:32G TF.CS 0x L[C8,70] R[C0,40]
041525 144012 547505  SERDES_RX_DFE      0.00,0.00,0.00,2.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00
041525 144012 547181  SERDES_RX_STATE    ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE006802
041525 144012 546810  TTS_SYNC           Pass:1 val:0x104 RX:32G TX:32G TF.CS 0x L[C8,70] R[C0,40]
The recommendation is to Open a case with HPE and ask them for assistance.  You can also open a case with Cisco TAC to request assistance.
Mark Elsen
  - Check logs on the MDS after trying to  make an intended connection (or configuration) ,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks Marce, a colleague is working with HP support to analyze the cause of the problem.
I will report the cause when we have an answer.
Jason Mooney
