03-25-2019 03:17 PM
Hi - This may be an easy one. I've just installed a pair of Cisco MDS 9148S fabric. I can managed them via putty, however while trying to manage them via Cisco Device manager, it doesn;t accept the admin password. Is there a configuration I am missing?
Solved! Go to Solution.
03-28-2019 11:53 AM
There are two userid/password combinations in an MDS switch.
userid/password
snmp-server userid/password
If you can telnet/ssh into the switch, then you have the correct userid/password combination.
However, DCNM and DM use SNMP. So they user the snmp-server userid/password combination.
You may need to update this password on the switch and try again.
Best regards,
Jim
03-25-2019 03:56 PM - edited 03-25-2019 03:59 PM
Read the FAQ : ( do the basic Setup)
config guide
03-28-2019 11:53 AM
userid/password
Best regards,
Jim
