Hello there,
In your design always keep in mind that both UCS FI are separate switches, they always will talk each other by the upstream switch. The best pratice is connect anything that have to talk with UCS domain in the upstream switch.
If there is no option to do so, you can connect through the FIs, using a appliance port. In your case I believe that connect stagger mode is the best option, but I'm not sure, depends how your vnics are configured and if your Dell EQ can do port-channel in active-standby mode.
